I have some Minn Kota Endura 55's, I put them on my rental boats for fishing. I have been having quite a few of them that have been coming in not working especialy in windy conditions. Usualy when I tear it down I will find the speed control switch is melted or the brushes are melted solid into there housing. I have been changing switches, brushes & there housings along with seals in the lower unit. The switches are labeled as to which wire to put wear, the brush housings are not.
Here is my problem, after rebuilding them I have had some of them that will run in reverse. ie instead of 3 speeds in reverse and 5 speeds in forward they will have 5 speeds in reverse and 3 speeds in forward? If I reverse the leads on the battery negative on positive and positive on negative the motor runs correctly? I have double checked the switch where these leads connect and they are hooked up properly according to the labeling on the switch.
Any suggestions?
Thanks in advance,
Len
Any suggestions?
Thanks in advance,
Len
