Minn kota drive not working
twinvee17
I have a minnkota foot control motor. I did not have it hooked up with a circuit breaker/fuse and ran it aground. The directional, left/right still works. I tried a friends foot control and problem was the same. Did a direct battery hook up and the motor worked. Checked tht control board and the positive wire coming out of the board (going to the motor) shows a open circuit when the motor is turned on. Do you think the control board is definitly my problem and should I replace it? I know of no other way to check it.
John Nutter
Re: Minn kota drive not working
Sounds like the control board to me. Before I spent that much money I would get it checked by a MINN-KOTA service center. Those parts are non-returnable after purchase. A lot to spend if that is not what you need
twinvee17
I appreciate the reply, and I think I will do that. thanks
