A 140hp in-line 4 mercruiser I am looking at got a bit overheated due to the stern impeller going out. Compression (cold) in all cylinders was 145-150 before we ran it. 2 weeks pass, impeller was replaced, and I checked it out again. Oil looked a bit milky before the run, buy afterwards it seemed clear. Compression hasn't changed, boat seems to run strong at WOT. Do I have anything to worry about? Even if the headgasket is leaking, is it a big deal to replace it? <br /><br />Thanks
