Hi, I have a 2005 bayliner 175 with 3.0L mercruiser. I didn't winterize it properly so ended up with water in oil. I drained the water/oil and replaced it with fresh oil. The engine turned over fine. I drained the oil again, it was still milky. I repeated this 2 more times and ended up with fresh oil draining. I was cranking the engine for approximately 10-15 minutes in between.
I'm planning on testing the boat in water next. I'm wondering that if there is a crack in gasket or block, would the water show up in oil when i take it out in water? The engine isn't really doing any work when I turn it on using the bunny ears. Thanks in advance for any useful information.
