Re: Milky liquid from prop??
I've got the same engine, 1994 40 4 banger,<br />It's less & less after each use as the fogging oil residue burns off..<br />I used my boat 3 times this season thus far, short trips only burned 6 gallons & I didnt see anything yesterday after flushing it.<br />The only other thing I thought it could've contributed to it was some of the marine grease & sealer, wd 40 I used in the LU when I did my waterpump couple weeks ago but that wouldnt come out of the exhaust I dont think.<br />What else could it be if the gear oil is good ..<br />It's just a little oil scum , looks like the oil mixed with moisture or condensation over the winter & slowly comes out looking like turkey gravy .. <br /><br />I'm no Marine Tech but I believe this is the situation & as I noted it clears up after you use the engine for a couple hours ..
