Re: Milfoil > pond = bass cover?
Your department of natural resources or whatever your state agency that oversees the waters in your state. <br /> If you really want to figure this out yourself than get a book on aquariums or ponds as it will inform you on ph, hardness etc that is needed on an enclosed eco systerm.These books will<br />give a more simplified approach to the many aspects of water chemistry. They are fairly simple and can give a good understanding of what to do.<br /> I have simple drainage ponds behind the house<br /> that are not quite deep enough to keep fish(only because of the winter weather). At the height of high water it is probobly 8 feet. Someone had the idea to get rid of the duck weed that was growing as it didn't look as good as they thought it would. They added a chemical to kill it and now we have brown water which they are complaining about. <br /> What I am trying to say is an enclosed ecosystem can be harmed very easily. Tread lighty and depending,on how many others on this semi private pond would be impacted, to see if the best <br />alternative could be found. <br /> In closing I would love to be able to try to <br />get a good bass pond going. Do a little research before you add anything into the pond. Good luck.
