Re: mikeyzx2 HELP!!!
My throttle is advancing all the way...need to take that cam apart and clean and re grease it. I was having the same ignition problem. A guy near me sells used parts. I got a powerpack, Stator, timerbase and carb kits for $150. I just replace everything, rebuilt the carbs(unbelievably easy) and did a decarb with seafoam. Ran great except for that timing issue. I was just getting tired of taking her out, only to run like crap. Plus now, I got all these extra parts.<br /><br />What have you done so far?<br /><br />1 Replace coils.<br />2 Coils sensers 8 ohms<br />3 charging coil ~650 ohms<br />4 power pack<br /><br />Are you sure you have spark...what cylinders are not sparking. Could it be clogged carbs. You have probably been through all this ...as I have. If I can hep let me know. I am pretty sure it was my powerpack that was bad...I am scared to put the old one on again for fear it might break something else.
