Mid - Late 80s yamaha 150hp new york
dennis8850
i have a complete 1986 yamaha outboard 150hp percision blend that i will be parting out if anyone needs any parts give me a call at 631-872-4397 my name is dennis im located on long island onl thing bad on engine is the trim rams, the tilt works but when it comes time to go any lower the rams only go in about 1/4 inch so i think there pretty much locked up power head is perfect as well as everything else, im just so tired of putting money into this thing, last season i put 1800 into it replacing shift rod, rebuilding carbs, water pump, and complete tune up,im just done messing with the engine 20 inch shaft all or most parts should be interchangable with most v6 yamahas but deff will work with 150hp engines years from 1984-1989 but maybe later years, if you have a percision blend engine its prob the same too. please just call 631-872-4397 because i dont have time to check this too often, and i will be putting what ever doesnt sell on ebay on monday. thank you
