jdstephwacotx
- Aug 16, 2004
- 53
I just picked up my very first boat yesterday. It is a 1960 Larson with a mid-70's Johnson 85HP. The guy selling it supposedly cleaned and/or rebuilt the carbs, replaced the water pump impeller, replaced the starter and cleaned the plugs after it had sat up for the last 5 or 6 years.<br /><br />I took it straight to the lake to see what I got myself into. It starts good. It idles good once warm. The engine will rev up good with the 'warm up lever' (I don't know the name of it). Once the arm is down and the engine is warm when you put in in gear it won't die immediately but once you push it all the way down it gurgles the dies. It won't rev with the throttle lever, just the 'warm up lever'. I don't have a tach so I don't know what RPM I'm getting. I am going by sound.<br /><br />It seems to rev better in reverse than in forward. I don't think I am supposed to but if I keep the 'warm up lever' full forward at the same time that I throttle forward I can putter around but as soon as I pull the lever down and push the throttle any further it dies.<br /><br />Any help would be appreciated.
