So I purchased a 1990 Sunbird from a guy who "just put $900 into freshening up the engine". Well I didn't notice the little hint he added saying "We always just puttsed around in it, never really got on it," until after it quit running the first time out.
So here's whats going on. It starts, hard, and barely runs. It sounds like one of the three cylinders is missing bad. I replaced 2 of the coils after seeing that the iron core was all busted up in two of them (replaced with Sierra instead of Mercury). Didn't make much of a difference. So I replaced the wires and boots on the plugs to make sure they weren't grounding out (they were a bit rough looking), no change. I used an inductance tachometer to check that there was juice going through each wire, which there was. But one wire seemed to read a much higher RPM (firing more often) than the others?
This makes me think its a timing issue. Not sure where to go from here. Any assistance?
About 126 psi in each cylinder, one fresh coil, one of the iron cores cracked during installation of second new coil (fixed with a copper wire to ensure continuity), and an older Mercury coil that still looked good.
Is there a way to test these coils? They are open loop from plug end to pos/neg and closed (no resistance) from pos to neg. Also, I believe the iron core just needs to provide continuity from top to bottom all the way around the coil, correct?
Thanks in advance for any help!
TJ
TJ
