metal shavings in lower unit normal?
oarfish
I bought a 1988 Mako 17 with a 1988 Johnson 120 past summer.My first boat. Soon after I noticed metal shavings on the magnetic plug of lower unit. A local Johnson service rebuilt the lower unit.After 4-5 Hrs of boating I did check the filler plug and find, fine metal fuzz stuck to it. Could that be normal after rebuilding ? Thak You for this forum! I think I am hooked.
JB
Re: metal shavings in lower unit normal?
Yes, Oarfish, a SMALL amount of fine metal particles is normal, particularly after breaking in/wearing in new parts.<br /><br />No worries.<br /><br />Red sky at night. . .<br />JB :)
MITCH WELCH
Here's your second opinion..... Yes this is normal. The only reason I offer the second opinion is because I see this is your first post and thought you'd feel better with several opinions. ;)
Hooty
How 'bout a third opinion. You'll get some shavings form the clutch. That's why it's good practice not to ease the engine into gear. Engage with authority.<br /><br />c/6<br /><br />hooty
Dhadley
Yes the "fuzz" is normal. If you use synthetic lube even the "fuzz" will almost be gone.<br /><br />Good luck!
Walter
"ENGAGE WITH AUTHORITY"<br /><br />Ya gotta like that term....
