Allan Ewing
- Sep 12, 2005
- 11
1991 Johnson 175 V6. While running it for winterizing it began to make noise from area of flywheel. Pulled flywheel and found three pieces of metal. If I have the correct names, they came from charging coils on the stator. Each of the three charging coils has three metal pieces that surround the coil which are held in place by a metal clip. One half of all three metal surrounds on one coil broke off and were sticking to the magnets on the flywheel. I was able to run motor and finish winterizing. I am wandering, can you even get just those metal pieces; they look simple to replace, or am I looking at a new stator. Will not be doing anything till next spring now.
