GIJeff
- Jun 5, 2012
- 41
Hi all,
I have a 2006 Tahoe w/ a 4.3L Mercruiser. I recently messed up the wiring on my stereo and can't get it to work right.
I had my stereo working (has worked for years), but last weekend I took the boat out and I accidently disconnected some wires when I shoved some bags too far up in the compartment against the wires. I have a head unit powering 2 speakers, and an amplifier powering 2 tubbies. The wires that were disconnected (that I could see) were the blue/white from my head unit that I had going into my stock boat wiring, I think it is to a purple wire which I thought was the ignition/remote turn-on from the boat, and then also the pos & neg for one of the speaker to the head unit. I reconnected the blue/white to the purple on the boat, and I reconnected the speaker wires. Amp turns on, head unit won't. I started wondering, was the blue/white not connected to the purple previously? I didn't see any other wires that looked like they had been ripped apart, so I didn't think there could be any other connection that I was missing. I have my yellow and my red from my head unit attached to my boat wiring red (power to the battery, I believe?) and to the blue amp remote turn-on. I have all 4 connected together. I thought maybe these were loosened during this whole issue, so I disconnected them and reconnected. Same issue, amp is turning on and getting power, but head unit is not. I think I have it connected the way it was originally, but head unit still won't turn on.
Another problem that just began: When I flip on the blower, it acts as though the Master Power is turned on instead (I think this because the amp turns on but the blower does not). Master Power seems to be working properly in addition to the blower switch seemingly turning on Master Power, too.
Everything worked properly until I mistakenly disconnected the wires and then likely did not put them back together properly. Any advice, please? Thank you all very much.
