nailbender
- May 2, 2005
- 5
Hello.<br />I have a 1986 3.7 4cyl Mercruiser engine in my boat.<br />At a hot idle @800rpm it will have about 5psi oil pressure.<br />It only gets this low after a near full throttle run or pulling a skier around and the engine is good and warmed up.<br />As soon as I bring the rpms up the pressure goes over 20psi and will go up to 40psi at full throttle rpm.<br />I was told by my mercruiser dealer that this engine has large main bearings and doesn't run as much pressure as the other mercruiser engines.<br />Its been this way for 5 years with no problems.<br />I've had a mechanical guage in it to verify the pressure and have tried a different sender so I know the guage is reading accurately.<br />My Clymer manual calls for a minimum of 15psi at 2000rpm so I think I am in spec.<br />I've tried 30w, 20-50w and 20-40w oil and the pressures the same with all of them<br />Is my hot idle oil pressure normal for this motor?<br /><br />Thanks.
