nailbender
- May 2, 2005
- 5
Hello. I'm new here.<br />I have tried the search feature and the other recommended helps before posting.<br />I have a 1986 Mercruiser 3.7 170hp that when I shut the engine off makes a clanking noise from the front of the engine.<br />It sounds normal while running.<br />I was getting the thing running for the year today and this popped up.<br />The noise was not there when I quit using it last season.<br />I listened in different areas of the motor while shutting it off to locate the noise and as near as I can tell it is coming from the flywheel/harmonic balancer area.<br />I have put a socket and ratchet on it and turned the engine back and forth. I can feel a little play and if I turn the engine over by hand I can get it to make the noise.<br />I can feel it in the flywheel as well.<br />My first thought was that the timing chain is loose or the tensioner is bad.<br />I'm wondering if a loose magnet on the flywheel could cause this noise from the magnetic fields switching.<br />I work as an auto mechanic so I have experience with engine noises, but this is new one on me.<br /><br />Thanks for any help.
