This Ship of Fools
- Jul 8, 2010
- 21
Have a 1976 Cobalt Mercrusier 233 with what I believe to be the MC-R drive I am replacing the sea water pump in the lower unit I purchased a Sierra 18-3317 kit everything looks close to the same but could not get the lower half of the new pump to set all the way so I reused he lower half of the old pump everything went together just fine I been trying to reinstall the lower drive to the upper drive Shift control is in forward shift selector spine in lower drive turned to forward ( lock prop so if prop is turned counter clockwise the lower drive shaft will spin .Have tried turning prop while installing This lower unit has a loaded pin on top that is very hard to compress if at all Is it this load pin stopping the drive from going in? The closest I can get the drive is to the point of the mating studs are just flush with the upper housing Any help will be greatly appreciated
