Mercury won't throttle up?
Dsundby
When I have my motor in neutral and rev it up to full throttle it will climb just fine, but when I shift into forward it won't climb all the way up even though it's at full throttle. It will only go at half speed.
ondarvr
We don't know what motor you have so it's a little difficult to help, but it's probably not running on all cylinders.
Dsundby
Could it be a spun hub, or the friction screw? A couple of times it has reached full throttle in forward, but when I slow up and speed up it is only at half throttle.
Chris1956
A spun prop hub is like a slipping clutch. The engine will rev up, but the boat will not speed up, and may even lose speed as the motor speeds up. Is that what you are seeing?
