I have a 90hp merc, 6cyl with 3 inline carbs. It's in the 80's but not sure. It runs terrific at higher rpm's but stalls when idle. If I hit the electric choke in time i can save it from stalling. Carbs are clean and adjusted well, but I do have leaks around the throttle shafts. I,m not sure if housings are worn or the shafts. There aren't any seals to change. Could this be the reason and if so how can I remedy it without buying all new carbs? Please help, its really hard trying to dock not being able to keep running.
