Trim motor works. I have emptied the hydraulic fluid out and replaced with fresh. No movement with hydraulic at all. I have attempted to get rid of all the air in the fluid, but still no movement.
Serial number G226225
1995 mercury force 75 horse
I lift the motor up and down manually to move fluid/ get air out of fluid.
I have left the cap off after refilling it and pushing the trim button. Fluid is being moved by the motor to the cylinder but no movement of the hydraulic cylinder...
A couple times after refilling with fluid motor would really bog down like it's trying to push fluid threw but can't ( or not much at least). Then It clears itself after I move motor up and down manually...
