jtwilson728
- Jun 16, 2010
- 5
Hello,
I have a 1994 Merc 90 HP. While on the water it began bogging down like it was running out of gas, so I pulled in to the bank. After finding it had plenty of fuel I tried to start it back up but it wouldnt even turn over. After getting it home, I tried turning the flywheel by hand. It will turn so far in one direction then stops. I can turn it in the opposite direction and it stops in the same spot. I took the plugs out and all pistons are moving. After doing this by hand several times, it began to turn freely without stopping. So I put the plugs back in and tried to start it. It barely turned then stopped. Now I have the same results, can turn by hand only so far and it stops. Any suggestions to what could be the problem?
Thanks,
Jason
Thanks,
Jason
