Re: MERCURY TEMP PROBLEMS
Hondon, thanks for response, but have already done the water pump and the housing.<br />also the thermostats and this started all at once, my guage use to read on the dash - 150.<br />Now it reads 100-125.<br />With the lazer temp guage, some cylinders will be as low as 120 and others will be as high as 170. <br />Hope you have some other ideas - could a head gasket cause the problem?<br />Are you familiar with a pop-it valve function?<br />I'll check back shortly!
