Mercury remote wire colors for tachometer
Blazer as
Need help with my new mercury tachometer leads color and operation on mercury remote?
GA_Boater
Welcome aboard.
I think those wires and connector are for tilt and trim.
Need more info from you to give you the tach wire colors. What motor and what is the serial number?
Chris1956
Mercury's newer than about 1978 will use a grey wire for Tach signal, plus black (ground) and purple (+12VDC).
The grey wire will originate at the voltage regulator or rectifier.
