I am trying to remove the powerhead from the lower unit of a mercury 200 offshore series (1992)I am positive that all the required nuts/bolts are removed, but CANNOT get the powerhead to break loose from the lower unit due to corrosion (i think) on the studs that run from the powerhead to the lower unit. Have tried using a lift and banged on it everyway i know how with no luck. Even lifted the boat up off the trailer with the lift and still no luck. ANY suggestions please!!!
