I have a 25ft Bertram fitted with twin Mercury outdrives 3litre mcm alphas with bravo outdrives 1990 (OC 764077)<br />One of the engines runs hot.I have carried out all the items listed below:there has been an improvement but it still runs about 30degrees hotter than the other engine.<br />A new exhaust elbow fitted and the flapper checked.<br />The exhaust manifold has been cleaned.<br />The head has been off and cleaned the valves checked.<br />A new impeller and a new engine water pump fitted.<br />The plugs are ok and the timing has been checked.<br />The problem is the same with or without the thermostat fitted.<br />The engine cools quickly if run out of gear.<br />The boat has recently been antifouled so there is not weed build-up.<br />I would be very grateful for any ideas.<br />DFH
