Mercury Outboard 9.8 hp Throttle problems - tiller controlled
Crabby96
I need to take apart my throttle control mechanics (wheels, cables, shafts) because there is too much resistance in the shaft that the control cables wrap around, to the point where turning the grip will not rotate the shaft. ..wondering if there are any tips out there on dis-assembly and lube.
Also, when I manually operate the shaft lever, I noticed that the ramp (not sure if that's what you call it), does not engage the throttle arm on the carb. Any help on either of these two questions would be much appreciated! Thanks.
Rob
Mi duckdown
Re: Mercury Outboard 9.8 hp Throttle problems - tiller controlled
Pics and serial number would help alot
