Hello to all,
Well I'm new to this site but thought if there's anybody gonna help me its gonna be you guys here. I have just recently acquired a 20' or so fibreglass( not quite sure on the hull model????) with a 80 HP Mercury outboard. I'm planning on restoring the boat this fall/winter and hopefully get it on the water in the spring/summer. The hull is in perfect order and all needs is a interior that I will be doing myself.
The engine from what I know of it is a Mercury 80 HP Thunderjet Ignition 4 stroke/ long shaft now let me explain my confusion. The serial number for the engine is a canadian number of 2991338 which I found on the left side of the engine when standing behind the prop. I looked up the number on the net and found it to be supposedly a 1971 model. Now the engine looks nothing like a 1971 model unless the Canadian models looked different??? I did more research and found the engine looks more like a 1980's model..... Am I reading the wrong serial number???? How else can I indentify the motor??? I havent been able to locate anymore serial numbers on the engine at all. I'll be doing a complete fluids swap and also need to change the fuel line from the carb to the intake manifold. Which is behind the starter and looks to be a pain in the butt. My father-in-law says that the motor ran last year and has been covered and out of the weather since( the hull has been covered and protected also). He just dosent have the know how or time to fix it up.
Wow I wrote alot....Anyways hopefully you guys can help me indentify this motor so I can get a manual for the thing so I can start turning some wrenches!!!!
Thanks for the help and looking forward to your response.
Thanks again
Budso_86
Mission, BC Canada
Thanks again
Budso_86
Mission, BC Canada
