Mercury outboard 200 hp EFI 6 cylinder wont get up and plane.
josh1980
I bought a 1999 Mercury outboard motor 200 HP EFI, it runs but took it out on water and it only went to 3000 rpm and then wont plane. Took it to mechanic and tested it. All the electricals are working except it showed all the cylinders were not putting out like should. So checked compression on all 6. All 5 were 90 and the bottom right side cylinder was 40. Like i said starts right up and runs just wont go over 3000 rpm and wont plane. Anyone know if it can still be fixed without rebuilding? Piston ring? Piston gasket? Etc?
Faztbullet
Get a different tester as it may be reading low. If numbers are correct its a hurt mota, pull head and inspect cylinders...
Dukedog
what Faz says but no mater what tha numbers read with 50 lbs difference on one its hurt and ain't gonna heal itself.....sorry.
