Hi,
I have a 1980 7.5 Mercury which sat for some time. I have redone the carb and got it runnung but now see it needs a water pump. I took off the 2 nuts holding the lower unit on but it's not coming off. I have done a few water pumps and know that the shift linkage needs to be free but I haven't seen a linkage setup like this before. Underneath the carb is a gear and the linkage comes from the gearcase and terminates there. It looks as if it is pushed up into a spline in the center of a gear which connects to another gear which is mounted on a square bar that runs to the shifting mechanism on the side of the engine but I don't see how it comes out. I thought i could just pull it down and it would free itself from the spline in the middle of the gear but it doesn't. Does the shift bar have to come out and the gear taken off the linkage from the top ..Any help woud be appreciated..
