I need some help with my dads 90 hp Mercury (Early 80's Model). We got a replacement lower unit (used), after the one on the motor split near the prop. However, on the replacement, the gear shift shaft slides in and out of the lower unit freely. The keeper pin seems to be missing, and I am not able to align the shaft with the cam that actually shifts from forward, reverse and neutral at the bottom of the shaft. Do I have to take it all apart just to connect the shaft and the cam? Are there special tools required if I do? Should I even attempt it myself, or take it to the shop? We now have three lower units for the motor, does anybody know who might be able to (inexpensively) get all three lower units combined into one that works (all three have stainless parts that would be better as we use the boat in salt&fresh water). This would also solve my gear shift shaft problem. Any info would help. Thanks!
