dswanson79
- Sep 10, 2008
- 8
I bought a used lower unit from the same year and hp as mine a 115 4cyl. mercury force. I installed a new impeller kit and went to put the lower unit on the motor and found that both the motor and lower unit have a silver metal tube coming out of the same spot (looks like the speedometer pickup its just in front of the f-n-r shaft) I need to take one of them out so that the lower unit will slip on flush with the motor. I gently tried removing after applying wd40 with no luck. Is there a trick to getting it off?
