mercury ignition switch
rrsuneson
any one tell me how to hook up an aftermarket ignition switch to a 75 mercury 50 hp motor the assymbley is mercury cant trace wireing cause they got everything taped up shure would appreicate any help on the color codes on the harnesswires nad how to hook them up right
SpinnerBait_Nut
Re: mercury ignition switch
Welcome aboard and I'm sure this will get moved to where it belongs.<br />Whoossshhhhhhhhhhhh!!!!!!!!!!!!!
rodbolt
repost in the mercury forum or have JB or another mod move this post. when I get back later if you have no replies I can help. I will need to know how the back of your switch is labeled,the old switch to if you have it. and we will need to know which control box you have.<br /> do you have the harness from the engine to the control box? if so post all the wire colors you have at the control box end.
Originally posted by SBN:<br /> Welcome aboard and I'm sure this will get moved to where it belongs.<br />Whoossshhhhhhhhhhhh!!!!!!!!!!!!!
Stumped, eh Admiral ;p :razz: :p :cool:
M
Mod3
Guest
Moving to Mercury and Mariner Troubles and Repair.
ricksrster
Here it is. Balck = ground; red = Positive from battery; Yellow goes to neutral inter lock switch; White is positive from ignition on; Orange ( Salmon ) is off / kill; grey is choke; Bown is tach.
