Mercury has very high rpms when starting?
Catman00
When I start my 115 hp ELPTO it revs really high, I shut it down due to the high rpms in fear of doing damage. I had it out the day before and it ran fine till I tried to go to neutral and it wouldn't go and it was stuck in gear, i got it on the trailer finally and worked the shifter and everything seemed fine. Does anyone have any ideas? Any help would be great, please let me know as I am stuck at home now. I have checked the controls and cables and everything seems good there.
Texasmark
What kind of remote control do you have? Assuming Mercury, for general use, side mounting there is a 2000 that sits on the bulkhead with exposed wiring and cables and the 3000 that is mounted in the bulkhead with cables and wiring concealed. The latter is easily recognized by a big black button used for fast idle.
On the 2000 there is a fast idle lever on the rear that must be ALL the way down before shifting. When using it, depending on your engine's preference, you may have it partially up or all the way up. Trick is to get the engine to light off and then move the lever as necessary to maintain the engine rpms at around 1500 give or take a few hundred while warming up. Then push it down. If the engine tries to die, just push in and hold the key till it recovers and let go. After it warms up somewhat it will quit needing the extra fuel charge.
On the 3000 depressing and holding the button down while advancing the control lever out of the N position, you are in throttle position only and the advancement of the handle controls the fuel and rpms. Once you leave the N position, the lever will lock in the depressed position and you don't have to hold it in. Work it the same way as the 2000 fast idle lever in warming up . When finished, pull the contol lever back to N and the button will pop out putting the lever back to the dual function mode where it controls both throttle and shifting.
Mark
Catman00
Thanks Mark for the reply, per your description, I have the 3000 although it is not mark anywhere on the controls other than Mercury on the shifter. I mess with the throttle only button and everything appears to be OK, also checked the cables and everything works smooth. I am unable to investigate anything while its running in fear of hurting something as it appears to go to full rpms as soon as it starts and I shut it right back off. I read something at a another forum about a trigger? Do you know anything about them or could this be my issue? Thanks again
