timmmaaay1
- Jul 9, 2015
- 3
20hp mercury 200. I purchased this boat and motor a few months back. It had been sitting outside uncovered. I cleaned the old gas out the carb and all lines. I got the engine running, and took it out on the river. It ran really good, I did run it all the way open. I shut the motor down so I could do some fishing, when I tried to start it again it wouldn't fire at all. I tried gas and either and the engine wouldn't even sputter, putter or anything. I am not a mechanic but I can read and follow direction. So after research I decided to check compression. I only have a pull start because the starter is messing, so I only got the compression up to 70 on both cylinders. So compression seemed good. the motor has a nice blue spark...one of the ignition coils looked real bad so I replaced it. Still no fire. I pulled the flywheel and the key looked fine. I did have to replace some wires because they were crumbling from age. Its been a few weeks and the engine has never fired once mot even with gas or either, I do spray the cylindes with sea foam lubrication after I use either. I do not believe its a gas issue since it never fired once, compression seems good, and it has spark, so can it be a timing issue? Can I check timing with a pull start? Im at the end of my rope here guys, I'm feeling discouraged because im out of ideas...I really need help here. What Should I do next? The engine is around a 1976 model.
