AirOPS
- Sep 2, 2012
- 17
Hello everyone,
First time poster here, and first time boat owner, as well.
I've set my boat in several times over the past few months, and the motor actually runs great with no hiccups whatsoever from startup to shutdown. However; it has always, upon first crank, turned over quite slowly at first, and then suddenly would "speed up" and immediately fire up. I've always attributed that issue to the Force 120 being a high-compression motor, taking plenty of juice to get turning. I tried to set in today and encountered the same old slow turnover, except that this time it didn't speed up and fire up. Sounds just like a nearly dead battery... that signature "Whir.... Whir Whir..... Whir" sound.
It's always plugged in while in storage via its Minkota charging system. When I left for the lake house Friday afternoon, both batteries had green Full Charge lights illuminated. It has sat for only 2 days unplugged, so initially I figured the battery is actually bad, and doesn't hold the charge if it sits unplugged for more than a day. The only problem, as you will see in the video below, is that even hooked into "house power," the same slow turnover occurs.
Please view this video, for your considerations:
I can't make any sense of this. Unlimited power from the wall outlet, yet it's apparently not enough to turn the motor over? Granted, I have a LOT to learn about marine systems, and so I won't mind criticisms. Thanks for any help, friends.
