goldammerr
- Aug 25, 2001
- 7
I have a Boston Whaler Outrage 21´ equipped with the above engine. Boat + engine were bought new in December 2000 and were used 5 times since then. Very low hours (<50hrs).<br /><br />Just recently, engine could not keep rpm above 3,000 and would die. idling is very irregular and a rattling sound started to emerge. Temperature above normal, not much.<br /><br />Upon pulling back into the dock, externally there was nothing out of the ordinary I could diagnose, so I had a Mercury authorized technician come in with similar results, ie, nothing.<br /><br />Authorized dealer suggested we open up the engine to diagnose. That was done and the diagnostic is that the oil pump (which in this model is mechanic and its power comes from a gear in the crankshaft via a "plastic" rod that connects to such gear. It seems incredible to me such a vital piece would be made of plastic, but anyway...<br /><br />The plastic rod broke for no apparent reason, thus very little oil was being pumped to the engine. No damage to pistons, etc., but, according to the dealer, the crankcase was slightly damaged by some pieces of the broken plastic rod.<br /><br />I have not yet seen the engine after it has been dismantled (i´m away on business) and although this is something that we both think the warranty will cover, my question to you is basically: does this make sense?<br /><br />r.
