sonoma_dog
- Sep 12, 2013
- 3
I am stuck! I just bought a 1985 35hp mercury outboard, Serial number: 6629125. I tried to replace the water pump and am not able to drop the lower unit. I have removed all five nuts as shown in the pictures!
After all the research on the internet, I am suspecting the drive shaft is stuck at the motor head. So I have mounted the outboard upside down, drilled a 1?1/2 inch hold and spray a LOT of liquid wrench penetrating oil in where I think the drive shaft is stuck (See pic) . After 4 days of penetrating oil / hitting it with hammer/ shaking it and the drive shaft still seems like it?s stuck there.
My first question is?. Is it really the drive shaft that causing problem? And if it is?..
WHAT SHOULD I DO NEXT?
1) Continual applying more oil / shaking it more
OR
2) Apply heat with a torch on the drive shaft. I am afraid that the shaft gets so hot cauing the plastic housing on the lower unit melt.
OR
3) Cut the drive shaft??and what to do afterward? how to remove the shaft from the motor head? And Can I weld it back together.
OR
4) Just grab a beer and say **** it?????.
Any advice will help! I really want to get this outboard working!
Thanks in advance!!!!
OR
OR
OR
