Mercury classic fifty on pontoon 9mph ????
Ltponline
I have a mercury classic fifty on a 93 crest 22ft pontoon. My top speed is 9mph , is this normal for motor and pontoon combination? 5 people were on it
roscoe
Thats kind of a big heavy barge for a 50 hp.
I wouldn't expect too much more.
What were your rpm's when running at full throttle?
what were the RPM's, and how deep was the cavitation plate? Pontoons are primarily a displacement hull (unless you have plenty of power and lifting strakes).
rough general rule the maximum speed of any displacement hull--commonly called its hull speed-is governed by a simple formula: hull speed in knots equals 1.34 times the square root of the waterline length in feet (HS = 1.34 x √LWL)
for your 22' pontoon, 6.3 knots (about 7.2mph)
jerryjerry05
RPM's at wide open??
​Prop on there now?
Boat stay in the water? Scum on the floats?
ondarvr
Had a 21' with a Merc 40HP, it went 17MPH with a light load. It was close to 9MPH with a 9.9 high thrust Yamaha.
