I have a 9.9, 2stroke. I am having an issue with water circulation. Thermostat in, very little pee. Thermostat out, pees a stream across the room. Since water is obviously getting to the power head with no problems, I have done the obvious and snaked out and blown out the pee hole port in the thermostat housing...Same symtoms. Failing a solution to the lack of cirulation with the thermostat in, can this little engine do OK with no thermostat? I've never had one of these heads off, so I am not quite confident enough to just try it.
Thanks, in advance for any advice!!!
Grant
Grant
