Mercury 9.9 HP Questions
Aldmar
I have a new Mercury 9.9 FourStroke. Run it yesterday for the first time.
1) I have seen the oil pressure light blinking during the start procedure.
It went off when the engine started. Is that correct?
2) After running idle the engine for a while I switched it off. I restarted following the
procedure for a warm restart, but when shifted into gear the engine went off.
It was very hard to restart it. Any suggestion? Thank you
bilge rat jim
The bliinking oil light at start-up is normal. Usual cause of a hard start on a warm engine is over-fuelling- make sure to start the outboard with the throttle closed. If the problem persists, take back to the dealer- that's what the warranty is for.
