Yes you are missing The accel pump plunger, springs and bottom case. There are also some tiny o-ring and stuff you probably can't get from Mercury. I got my O-rings from Tohatsu, they may have the individual parts you need. My concern is what ELSE IS MESSED UP, and by who? the motor should fire if you spray gas in the carb. It will run without the accel pump but there will be some leakage. I think you have a motor that was worked on by a hacker. You need to take it to a good mechanic that is familiar with the Tohatsu/Mercury. It could be simple... or not. A 15hp carb is about $275 from Mercury and may be the cheapest way out. If you had all the parts it should take less than an hour to assemble it, but what if you have other problems? How did you get this motor? The carb kit doesn't have accel pump parts, they have to be ordered separately. The carb kit is about $50.
