Mercury 850 85HP Trim Problem
bassloverky
Does anyone know the oil ration for an 850 85HP motor. I think it is an 80s era motor. Just bought the boat and the previous owner didn't use the boat and has no idea.
I am also having a trim problem. I was told by a repair shop that the trim was probably added to the boat. This is my first boat that used a gas motor. From what I can tell the trim motor is working (whining) but it may be low on fluid. It trims down but wont trim back up. Unfortunately I have no idea how to check the fluid level. I have located the trim pump/motor but can't find any place to check the fluid level. I realize more information is probably needed but I don't know were to get it.
Also if anyone can tell me the year and any other info on my motor I would appreciate it.
Serial # 451193
Thanks in advance
Plainsman
Re: Mercury 850 85HP Trim Problem / Year info/ Oil Ratio
Welcome to iboats!!
Motor is a 1976
Fuel ratio is 50:1
Look for a straight slot screw on the trim motor, that will be the fill. You can use ATF or something like 20 w oil in it. I do not know the proceedure for bleeding the system, but you can do a search for bleeding tilt/trim.
bassloverky
Thanks! Sorry about the duplicate post for the year question.
bassloverky
Thanks! I love this forum. I would be lost without this info.
Any recommendations for a service manual for my 1976 Mercury 850 85HP? I should probably pick one up. It might save me some money down the road.
Smig
I would recommend the factory manual and an aftermarket one - the factory for just about everything, but the aftermarket for some simple directions.
oldmercs.com and maxrules.com are two places that sell the factory manual. I found both of mine on ebay...
Smig
bassloverky
Thanks to everyone for your help with the trim problem. I was able to figure out what everything was on my trim motor by using the PTT manual. It was low on oil and I added SAE10W30 following the manuals instructions. The trim works great now!!!
