Twin Mercury 80 HP 4STK (2007) not turned over in 2 months. Hot climate and stored under shade. Port engine fires up immediately. Starboard engine does not crank. Starter engages but cannot turn flywheel.
Attempted to manually turn flywheel but very stiff. Removed all 4 spark plugs and manually turned flywheel. Lots of gasoline vented from lower two cylinders. Initially flywheel was stiff, but then was able to make several smooth complete rotations. Additional gasoline vented from lower cylinders as the flywheel was manually turned. I do not know if this is normal but seemed excessive.
Cleaned up gasoline and made safe. Re-installed and torqued spark plugs and pencil coils. Tried starting but issue not resolved. Tried to manually turn flywheel, but was again stiff and would not move past a certain point.
Since flywheel turns smoothly with the spark plugs removed, the issue seems to not be a jammed impeller or seized piston rings. Any thoughts or guesses before getting the workshop involved? Thanks in advance!
