Re: Mercury 78A? Anyone know anything about it?
I'm sorry, I got a bit lazy.. I was hoping just because I wasn't familier with boat engines there was some magic button to start it that I was missing.
I started troubleshooting like I would a car.. pulled one of the plug wires and got no spark at all, the wire going to the ignition coil was held together by a splicer which fell apart when I touched it, so the motor is going to need a bit of rewiring.
Going to try replacing that ignition coil wire that's corroded to see if it gets me spark, if not I'll rewire the whole thing.
I've already fallen in love with this stupid engine.. I see friends and family, first thing I tell them is "I got a boat! and guess what, it's from 1958! the motor doesnt' even have a gearbox, cool, huh?"
Hello-
I know, I'm a bit late to the party :redface: but I can help you with all kinds of answers about your Mark 78a
I
hope you haven't gotten discouraged and given up this last year!
1958 was the first year these were made by Mercury. They called them "Direct Reversing", or as others have mentioned; "Dock Busters". As others have also said (and you yourself have noticed), there ain't no Neutral, just Forward, Reverse, or off.
You start the motor in one direction to go forward, then to go to reverse you move the lever back and hit the starter button again to start the whole motor rotating in the OPPOSITE direction! This was Mercury's answer to their belief that the gearbox (lower unit) wasn't strong enough to stand up to a six cylinder engine!
The reason they were called "Dock Busters" was if you approached the dock, tried to start it in reverse and it didn't fire in time you rammed the dock.
Video of a Mark 78a in use:
http://www.youtube.com/watch?v=hU-hZOnvg1E
Overview of the engine:
http://www.eastcoastmarineservice.com/mark78a.htm
OK: some links to a LOT of guys who know lots about these engines (repairing, parts sources, setup & tuning, oil mix, etc etc.)
John's Old Mercury forum:
http://www.pfs-ware.com/talkshop/
Fiberglassics:
http://www.fiberglassics.com/forms/forum818C/
East Coast Marine:
http://tinyurl.com/cwqbef
Antique Outboard Motor Club Inc:
http://www.aomci.org/
These are just a few, there's many more.
From the photos, you
do have the right control box there. That model should have two micro-switches in the box to control which direction the starter turns.
For troubleshooting the ignition, try here:
http://www.maxrules.com/oldmercs/timing/1.pdf
Internal wiring harness:
http://www.maxrules.com/oldmercs/Wiring/0_1965a/5.pdf
External wiring & control box:
http://www.maxrules.com/oldmercs/Wiring/0_1965a/1.pdf
Carburetion & fuel:
http://www.maxrules.com/carbindex.html
If you need more help (encouragement etc.) I can be reached through this board, or on Fiberglassics as "Captain Jack".
Smooth sailing!
The Cap'n
