Mercury 70hp Blueband
Nigel
I have a Mercury 70hp Blueband engine serial no 3334958. I was wondering if anyone could tell me what year it is.<br /><br />Also I'm having trouble starting it. It rolls over ok but just doesn't seem to fire. The fuel has been in it since last season...does that make a difference. Also I changed the spark plugs and stator last year, but it's still not going.<br /><br />One last thing. When it was actually going and we had it in the water...it didn't seem to have enough power to pull the skier out of the water. I bought the boat late last summer and don't really know much about boats to be honest, but is this size engine enough to waterski with. The boat itself is a 15 ft armstrong super v.<br /><br />Thank you...any advise would be appreciated.<br /><br />Nigel. :)
ehenry
Re: Mercury 70hp Blueband
Nigel, old gas makes a big difference. You need to use fresh gas. That 70, depending on compression, should be enough to get a skier out of the water on two ski's. It also depends on how many folks you had in the boat at the time and how heavy the skier was. I learned to ski behind a 25 horse engine when i was a kid and only two people in the boat.
petryshyn
I'm guessing she's a 1973.<br />Check it for spark...its not uncommon to lose a cylinder with those packs. If you do, it'll be a dog but still idle smooth...<br />Another thing I've found is by giving only a small amount of throttle and full choke with key, it starts easier.
Trent
Hey Schematic..Have you had time to check out the underwater camera yet..Still wondering if I would want one?
petryshyn
Hi Trent<br /><br />The water is still hard up here. Probably be a month or two yet before thaw.... I'll be sure to record a few snap shots for you. :)
Nigel
Henry,<br /><br />Thanks for the advise. Changed the fuel and made sure I got it all ut of the line and refuelled. Re-Charged battery and she started within 3 key turns after sitting out all winter. Let her run for a few minutes (the neighbours loved that!) We're taking her out tonight to try the skiing. Last time I tried I had 2 guys in the boat, and me in the water. I'm about 200lbs so it has some work to do. Anyway thanks again for the advise. I came across this website yesterday and I'm very impressed. It's great knowing that I'm not alone !!. Thanks again.<br /><br />Best Wishes,<br />Nigel :D
Kiwi
Hi Nigel, when you try out the skiing and your still getting dragged along with half the lake in front of you :D you might want to check the prop size. You might have a prop that is good for cruising/speed but slow to get the boat up & planing. If you have a rev counter let us know what the rpm is at full throttle.<br /><br />Cheers<br />Mike
Nigel
Hi Kiwi...I'll check it out this weekend when I'm out and I'll let you know. Thanks
