Mercury 7.5 hp Carburator Problems
cl65ca
I have a 1982 7.5 mercury outboard(serial 5938561 - the 7902 carb version) that I recently did a carb overhaul on (soaked it, sprayed it out, new gaskets, float, etc.) I've done this a few times before and have never had a problem. This time, when I put it back together I get excessive fuel spraying out a little brass tube next to the butterfly valve.(see attached picture, I'm pointing to the brass tube in question) I figured it was a gasket that was leaking air ....so I rechecked everything to no success.......Any ideas would be appreciated.photo1.jpg
cl65ca
Re: Mercury 7.5 hp Carburator Problems
Yep I replaced needle, seat and float as this was my first thought about problems too. I tried blowing in the intake and flipping like you said and it seemed fine. Should I try a different kit?
