Mercury 65hp four wiring harness.
Hi guys, I have recently purchased the above engine, someone has removed the ignition switch from the harness, trying to find out what wire goes where. It is the 8 pin round plug on the enginge end, and seven wires at the ignition end. can anyone help<br /><br />Thanks DB
Laddies
Banned
Re: Mercury 65hp four wiring harness.
Need the year, type of ign. system and serial number as some of the 4 cyls. were built with magneto or CD ign in the same year
Thank you for the reply, I do not know the age of the engine, and as for the serial no, the only one I can esee that may be the serial no is 37383. The ignition switch has 5 terminals with the letters A, E, B, G, F sorry this is as much info I have at the minute<br /><br />thanks again DB
joblo33
On early MerControls, which is what this engine would use, On the back of the ignition switch it's:<br />A-Red<br />E-Salmon<br />B-Yellow<br />D-Black (from tach plug and harness)<br />F-White (from choke and from harness)<br /><br />The colour-letter code for the entire engine plug is:<br />A-Red (+ From Batt)<br />B-Yellow (Neutral Start Switch)<br />C-Gray (Choke)<br />D-Black (-)<br />E-Salmon (not sure :p )<br />F-White (+ For Engine)<br />G-Brown (Tach)<br /><br />Hope that helps,<br />Eric<br /><br />Edit: Sorry Laddies, added some stuff to my post before seeing your post)
Laddies
Banned
And the gray wire in the harness is for the choke
Thank you Eric B for your assistance, believe me it is greatly appreciated. Can I ak you one further question regarding the wiring of the ignition. how do I wire the grey for the choke?
ricksrster
On the older control, there will be a choke button switch on top of the control. A white wire from the ignition switch goes to one terminal on the choke switch, The grey wire goes to the other terminal on the choke switch. Salmon is motor off. In the motor it connects either to the magneto or to the switch box to kill engine depending on your ignition. I think on distributor models it might not even be used.
Ireally should sit down and think of all the questions I need to ask, but guys I really mean a big thank you for all the assistance so far. With your help I have managed to get the engine to run (first time!!)I still have a couple of questions. Rick I take it the white wire comes from the white wire on the ignition? What procedure do I need to wire the tacho, and what type of tacho do I need. Being an older enine I am persuming it is a 2 stroke. That being the case what is the mixture. I also have an opportunity to convert the engine to run on propane gas I am assured by the people that convert the engines that it is a very successful conversion<br /><br />Regards DB
ricksrster
Yes, the white wire to the choke comes from the same terminal as the white wire on the ignition switch. To hook up the tach, you will have to run a wire from one of the yellow wires on the rectifier. Either yellow will work. The othe end of the wire you will connect to the signal terminal on the tach. Set the pole/pulse switch on the back of the tach to 12 pole/6 pulse. For tach instructions also see http://ww2.tflx.com/PDF/99320.pdf Teleflex tachs work good.
