Troy_from _Oz
- Sep 29, 2002
- 126
Hi, I have an old (70-72?) mercury 650 4-cylinder which seems to run really well- most of the time. It generally seems to start easily, even if left for a few weeks. <br /><br />The problem I am having it that when I stop the motor, then try to restart in quick succession, the motor will fire up - initially, then either die after a few seconds, or when I put the motor into gear. I can sometimes get the motor to continue to run if I shift into gear aggressively. If I try to do this softly, the motor dies. It is then difficult to restart.<br /><br />Compression is 130psi +/- 2psi (good but possibly indicating carbon build up?). Spark plugs are brand new.<br /><br />Any help would be greatly appreciated.<br /><br />Many thanks - Troy
