Mercury 60hp Bigfoot EFI stalls
Knight320
Over the past couple of weeks when I was driving at three quarter speed and then slowed down the engine stalled. Both times it took a few minutes and started right back up like nothing happened. The third time I was going about half speed and it stalled and I couldn't get it back running again. It seems like its not getting fuel to the engine.
I would assume to change the fuel filter, any other ideas?
Thanks
Silvertip
Re: Mercury 60hp Bigfoot EFI stalls
And check for spark on all cylinders. Water in the fuel? collapsed primer bulb when the engine dies? Bad fuel pump? ECU going bad? Just a few causes. The fuel filter is rarely the cause for a fuel starvation issue on an outboard.
Knight320
I took it to the Marina right near my house and they said that it is electrical and the fuel pump is not getting power. I recently had an ignition / wiring issue so I wonder if it is related.
thanks
