I think I sucked a rock or somthing into the pump. I turned the motor off and tried clearing the debris. I didn't visibly see anything, but here is what my motor is doing: It operates fine a idle and low speeds, but when I throttle up it seems like the impeller is slipping. The rpms go up but the motor will not bite and take off.
I don't know if there is some type of sheer pin on the impeller or what.
I thought I would get some advice before I started ripping things apart...
Any help would be appreciated!!
