Mercury 5hp 2-stroke Idle screw setting??
fatalbert43
Does anyone know the correct starting Idle mix screw initial setting for a Mercury 5hp 2-stroke, 2004??
Texasmark
Most carbs start at 1 1/2 turns out from closed. Be extremely careful when you close (screw in fully) that screw as it's brass and conical and if you screw it in too hard you can cut a grove on the cone which makes setting up almost impossible. After that setting, if you don't get the engine to light off and hold rpms at idle when you shift into gear, you need to open it up a little more at about 1/8 a turn at a time till it will do as I said. Final test is goose it in gear and it takes the throttle. If not, open a little more till it does.
Sea Rider
It's a combination of mixture screw 1 + 1/4 turns and idle screw settings. Start as suggested and adjust idle along till engine runs even.
Happy Boating
